  1. Xvid 1.1 (although same problem with 1.03)
    VirtualDub 1.5
    DV .avi (31 mins 4 seconds long)
    Lam MP3 codec at 224 kbps
    Using the following Vdub filters in this order: [full processing mode]
    - Deinterlace: discard field 1 (NTSC file format and plays back fine on my PC monitor without any jerkiness as far as I am concerned)
    - Lanczos3 resize to 320x240 (from 720x480)
    - levels (increase gamma by 1.3)
    - brightness increase by 7%
    - Smart smoother HiQuality (2.11) [Klaus Post] - based on filter by Donald Graft]
    Xvid settings are
    - 2 pass VBR
    - target size on second pass = 666167
    - Profile AS@L5
    - Quantization H.263
    - Quarter Pixel
    - Packed Bitstream
    - B-VOPs (max = 2, ratio = 1.5, offset = 1)
    Advanced:
    - Motion Search Precision 6 Ultra High
    - VHQ Mode 1 [Mode Decision]
    - use VHQ fro bframes too
    - use chroma motion
    - turbo
    Quantization:
    2 31 2 31 2 31
    - use trellis quantization
    Video ended up being 377 MB instead of ~ 700
    I'm assuming that this is because of the resize, but is there any way for me to compensate for it when setting target size? Or do I just have to guess and make it approximately double what I have now?
    Thanks.
  2. Been doing some reading on the Doom9 forums (which is taking forever) and it seems like setting Quantization to 1 instead of 2 might help.
    I'll try that and report back, but if anyone has anything else to add in the mean time, I'd still appreciate it.
    Dec 2004
    Australia
    Well 1 is default, however you may have problems with the default overflow settings as your 2nd pass filesize looks like it must be much larger than the first. I would suggest a higher resolution and or a higher quality matrix.
  4. Thanks.
    I have VDub set up for several different coversions (batch) overnight with different settings.
    I was just reading a bit about custom matrices (pretty new at encoding) and will try the 6of9 one as my bit rate is on the high side i.e. ~3000 , since the clip length is so short. Will have to use it tomorrow probably though as I'd like to see how the 4 encodes I have waiting to do tonight turn out first.
    Will play with resolutions after that.
  5. Interestingly enough, all 5 of the conversions I made last night came out with the correct size of 700 MB.
    Two were slightly larger at 701 and 708, but the other three were dead on.
    One was a 3-pass DivX file instead of Xvid though.
